Dynamic field caption
I will try to make it clear.
In the window caption or label there is only a Distribution description possible, the description is always the same, doesn’t change with moving the slider, so it’s static nor dynamic. It would be cool if users could reference to a field or to results of calculations and highlight that data the text for example by a different color.
For example: if I describe something in caption or label to make clear what happens when moving a slider, I also could mention a forecast coming out of calculation below the slider. The description below a slider could be: „if you choose 3% interest changes , It will cost you 3,- per year“ In the description the 3,- will be a interim, always changing result for only one slider. If you have many, and you don’t want to show them all in the calc field, it could be nice to simplify the calc and show only the final results in the calc and all the dynamic data in the label or caption.
Dimitri Geizenräder
Otto-Brenner-Strasse 86
D-45549 Sprockhövel
phone 49 (0)176 22 36 11 83
info@dimitri-geizenraeder.de
von unterwegs gesendet
Ah, now I get what you mean, thanks for clarification!
Unfortunately, there is no way to achieve this now. I’ve moved your suggestion to a separate request.
If more users upvote this idea, we’ll try to consider it in the future updates :slightly_smiling_face:
