Add tooltips to Calculator input fields
Hi Team! It would be great if we could just turn on a little “i” on the input fields so that it could temporarily display the field’s “hint”, instead of making it a permanent line under the field (Caption), which makes the calculator taller/longer. Thank you!
Hi there, @user20442 and welcome aboard :wave:
I really like your suggestion, thanks for sharing! If this request gets more support from others, it might be considered in the future :slightly_smiling_face:
