Display Weight categories as a result
I have just tried to use the BMI calculator. I want an option where it can display the user’s weight category (overweight, normal weight etc) and It can also display health advice depending on the weight category.
Unfortunately, this can’t be done because there is no text format. The widget needs to go beyond number, currency and percentage formats.
Hi there and welcome to the Community, @Fit_and_Well :waving_hand:
I totally agree that the built-in text result options would be a great enhancement and we’ll try to think it over in the future updates.
As for now, I’ll be happy to check with the devs if there is a custom solution for you. Could you just share all weight categories you’d like to show and their weight intervals?
