Hello, the opening feedback column is not centred and the text comes out of the column so that it becomes unreadable, also the closing ‘X’ passes under the text. Thank you I await correction.
Hi there, @Davide_Tartali ![]()
I am so sorry for all the inconvenience!
Our devs are aware of the issue and doing their best to fix it as soon as possible. I’ll update you once any news comes up ![]()
The issue is fixed! Please check your widget and let me know if it’s fine now ![]()
