Reviews Widgets displayed only half
I am using three review widgets (Opentable, Tripadvisor, Google), but only a section of each widget is displayed as if it were cut in half. The page is made in HTML and CSS for the styles.
Hey there @Ivan_Zavala :wave:
There was a conflict with your website’s styles. We’ve fixed the issue by adding this code to the Custom CSS field on the Appearance tab of your widget’s settings:
.es-main-container * {
  text-align: left;
.swiper {
	width: auto !important;
Please check your widgets and let me know if they are fine :slightly_smiling_face:
Thank you so much, Max! My problem seems to have been resolved. :ok_hand: :100:
That’s awesome!
You are always welcome :wink:
