Display only results for printing
I’d like to exclude fields and their values along with the widget title from printed versions.
Hi @Max That’s not what I meant. :thinking:
You mentioned that you’d like to print the results only, while currently it also includes the fields and a title, isn’t it?
Yes, that’s correct. But the implemented widget feature only ever prints the result section. Neither the input form fields nor the widget title are printed.
This isn’t a new suggestion, is it?
With the current setup, the print option includes not just the results section, but also the calculator field values along with their titles.
You mentioned you’d prefer to print only the results, which means excluding the field values and the title. However, I’ve edited the title to avoid confusion and better reflect your idea.
Please let me know if this clarifies things :slightly_smiling_face:
OK. No problem. For me, it’s always just about the results section that gets printed. Let’s just leave the suggestion as is.
