Display Instagram reels in feed format
Hi Team I want to display Instagram reels in feed format on my site for example you can see this website https://midnightangelsbypc.com/ the website buit on shopify and they have used the reelkart tool can you make some thing like this also as they give floting option its awsome
Hi @Anurodh_Keshari :wave:
We have Intagram Feed app where Reels are supported. If you have different posts in your profile, but need to display only Reels, you can use filters to show or hide posts containing keywords or hashtags.
Please check it out and let me know if this meets your use case :slightly_smiling_face:
Hello, I do not see an option to filter for reels only. The widget shows only my main feed, not my reel feed.
Hi there, @Oliver_Wassef :wave:
RIght now, this filter is not available in the app. The only solution is to display only Reels is to add URLs to these videos:
We also have a Wishlist request for an app that will display only Instagram Reels. You can upvote it here - Instagram Reels
