Is it possible to display or toggle on & off the a marker on the map that displays current location for better guidance.
Hi there, @Josh_Harvey ![]()
You’d like to hide the marker of an active location if the location popup opened on the map, am I right?
we were more thinking along the lines of having a visual queue similar to google maps where you can see your current location. Ideally this could be switched ON or OFF on the settings panel
