Store Locator: How to display location popup on pin hover
Want the popup with the location info to automatically appear on pin hover? Here is a solution from our awesome devs:
util.addListener('.maplibregl-marker', 'mouseover', (e) => e.target.click());
Add this script to the Custom JS field on the Settings tab of your Store Locator widget’s settings and you’ll be fine :wink:
Watch this video to see how it works:
Guys, was this solution helpful? Let us know in the comments :slightly_smiling_face:
