Hello. The deleted posts keep showing after we delete and double posts. It doesn’t look good.
Hi there, @Khanh_Scott_Dinh
I’ve forwarded it to the devs and will update you once it’s fixed
The issue is fixed! Please check your widget and let me know if it’s fine now
I am having the same issue. A deleted IG post from April 30th still appears in the widget feed.
Scroll towards bottom of page to Jersey City Pride Instagram
The April 30th post was deleted.
Here’s is our IG page Jersey City Pride (@jerseycitypride) • Instagram photos and videos
I found a workaround. It requires creating a new widget, therefore going through all the settings and everything involved with making a widget. Not ideal at all. But at least my widget IG feed is correct now.
Hi there, @Erik_Smith
I am really sorry about this inconvenience!
If you face this issue again, please let us know, and we’ll gladly remove it from your feed, so you wouldn’t to create a new widget for this.
We also agree that it would be awesome to automatically remove deleted posts from the widget, and this idea is already on the Wishlist. Feel free to upvote it here - Remove deleted post from the feed automatically
