We use store locator to display businesses in a geographic area, howerver if someone from outside the region enables location services it shows no results in the area. Is there a way to allow users more than X miles from your service area to see a set location, while users inside the geographic region see their current location and nearby businesses??
Hi there, @user2005
Just to clear things up: you’re talking about allowing the browser to get your location, right?
So, that when users of a specific location enable this option, the default location is displayed for them, am I correct?
Yes and no; for example if a user pulls up a map and is in St. Louis I’d like to it show their current location based on geolocation data; however if the geolocation data is more that say 100 miles from 63109 the view would default to that zip code that the user
Got you, thanks!
Currently, it’s impossible to achieve this. However, we’ll have this idea in mind and see for more votes from the community
