Custom Review Selection and Display Order
Hello,
I’m wondering if there’s a way to display only selected reviews and arrange them in a specific order with CSS codes or any other methods.
For example, I’d like to show the selected reviews in the following sequence.
  1. Review from Person B
  2. Review from Person C
  3. Review from Person E
  4. Review from Person A
Is this possible with CSS codes or is there a workaround you could recommend?
Thank you in advance for your help!
Best regards,
Hi there, @Aiden.Y :waving_hand:
You can choose only specific reviews using the Include filter (Reviewer Name or Keyword):
However, unfortunately, it’s impossible to set a custom order for reviews. We have a similar idea on the Wishlist and you can upvote it here :slightly_smiling_face: -Sorting reviews to show your best first
