Add a custom mask feature that will allow you to to display a custom phone input instead of just digits.
For example when the user types 3616666666 the user would see +1(361)666-6666 in the form block.
Something similar to this example.
A huge thank you for adding your idea to the Wishlist!
We’ll try to take it under consideration in the future and I’ll make sure to update you here in case of any news ![]()
This has been a wishlist item for a long time.
Hi @Hugh ![]()
Thank you! Yeah, we already have a similar request for the Form Builder app, and we’ll try to consider this feature for the Contact Form app as well ![]()
Max, What about instead of implementing this feature server side, would the possibility of allowing a phone number mask script like this be a possibility on the user side?
Please let me discuss it with the dev team. I’ll get back to you tomorrow ![]()
Our devs will try to customize your widget this way. My colleague Renata will keep you in the loop in a support ticket ![]()
Hey everyone!
We’re thrilled to share that custom masks for the Phone fields are already available in our Forms ![]()
Check this post for more details - Forms: Enjoy new Phone field with country selection, dynamic masks and validation! ![]()
