Custom code widget
A widget to add … custom code
Yeah sounds dumb but I work with an app development company that charges $100/h of work, if I could just add some code (other elfsight widgets) without them charging me that much for a widget that’ll be nice
Hi there @AELU_Media :wave:
Thank you for sharing your idea!
It would be great if you could provide more details on your use case by answering the questions below:
  • What settings should be available in this app?
  • What kind of custom codes should be supported (HTML, CSS, JavaScript)?
  • How would you prefer to add the custom code (text editor, drag-and-drop interface, etc)?
  • Do you have an example of the app with the similar functionality?
Any additional info would be much helpful :pray:
You can add code within the code widget
So if you don’t have access to website code, give it it to the developper and from Elfsight i can add code (including elfsight widgets) within the widgt code
Hi @AELU_Media :wave:
It appears you’ve already added this idea some time ago. Could you please answer the question from my previous message in this thread?
This info will help us better understand your idea :slightly_smiling_face:
Hi yeah absolutly !
  • settings : type of code ? header / body ? type of code (essential, marketing, …) for cookies
  • kind of code : basic html, css / js, just so I can add later on lets say GTM code or another Elfsight Widget
  • Wix code ! in wix you can add custom code to your page in the settings
Thing is, a lot of people pay for a software but when you want to make minor changes (make a button dissapear in css or whatever), there’s high fees
If I could have an Elfsight code widget added from the beginning from the company, i could do these changes my self !
Best
Arnaud
Hi there, @AELU_Media :wave:
If I got you right, you just don’t want to additionally pay to your devs for the installation and customization of Elfsight widgets. Is it corrrect?
In this case, you can contact us any time, and we’ll assist you with the installation or customization of your widgets absolutely for free :slightly_smiling_face:
