CSS - Change fonts on standard slider
Hi,
Does anyone know the CSS to change title and text fonts in the standard slider? I have found it for the testimonials slider, but can’t find CSS anywhere for the standard slider. Have checked all over!
Thanks
Hi @Will, welcome to the community, very happy to have you join us! :hugs:
This CSS code should help, please try to add it to your widget Custom CSS section:
.eapp-slider-badge-component{
    font-size: 24px;
    color: red;
.eapp-slider-title-component{
    font-size: 34px;
    color: red;
.eapp-slider-text-component{
    font-size: 19px;
    color: green;
.eapp-slider-button-link{
    font-size: 19px;
    color: yellow;
Please let me know if it worked :slight_smile:
Hey Helga, thanks so much for the fast response! This is great, I was also wanting to change the font so it matches brand fonts on the website - is this possible?
Thanks,
Will
Hi Will,
You can add the following code if you want to use the same font for all slider elements:
.eapp-slider-slide-elements {
    font-family: Arial;
Alternatively, you could add font-family to each element in the code Helga gave you:
.eapp-slider-badge-component {
    font-size: 24px;
    color: red;
    font-family: Arial;
Let me know if it helps!
Amazing, thanks Masha - and thanks Helga. Great community, you rock! Cheers
Any time, Will! :heart_eyes:
Hello, is there a way I can change the font to Oswald? Thank you!
Welcome to the Community, @user17612 :wave:
This code should help:
@import url('https://fonts.googleapis.com/css2?family=Open+Sans:ital,wght@0,300..800;1,300..800&family=Oswald:wght@200..700&display=swap');
.eapp-slider-slider-component {
  font-family: Oswald;
Please add it to the Custom CSS field on the Advanced tab of your widget’s settings and let me know if it worked :slightly_smiling_face:
