Countdown timer premature
I have been building a few pages using the countdown timer and all of a sudden this morning I can’t seem to get to the page anymore, and I realized that it is automatically sending me to the redirected page as if the countdown timer is finished. However, it is not finished. This link takes you to the page where one timer sends you to a page and then the second timer is supposed to kick you out to the openandclear.com but both of them shoot you right across as if they are complete and they are not. The first one set up to trigger morning of the 16th and the next one is supposed to trigger the morning of the 17th of this next week. I have high hopes that it’s going to work properly on that day. If you see the proper page that this link is supposed to take you to it would be a dark blue background, not a white background - http://uecreed.org/midway.html
Hi there, @Rev_Devan :waving_hand:
Since the redirect occurs instantly, I can’t see the widget on the website, unfortunately.
Could you please share the name of the Countdown Timer widget, which is installed on this page? I’ll be happy to check it for you :slightly_smiling_face:
It is both the first two on my dash board. I don’t understand how both of them are doing it. They both have Midway in the name.
Got it, thanks!
I’ve forwarded this issue to the devs and will update you once I have their response :slightly_smiling_face:
We’ve applied a temporary fix to your widgets, and the global fix will be released tomorrow.
Could you please check your website and let me know if everything is fine now?
Yes it appears to be working.
Hey there,
The devs reported that the issue with the redirect was fixed up globally, so all the timers are safe from this bug now!
Enjoy :tada:
