Copy to Clipboard - Request
Create simple button to copy predetermined text to user clipboard. Possible?
@Alan_Noble I think it would be a nice widget, thank you for your suggestion!
I’m not sure that I can promise a fast release, but I’ve shared your idea with the team so that they evaluate it and perhaps add it to the roadmap :slight_smile:
Anyways, I’ll keep you in the loop.
Thanks a lot for your help and yes, welcome to the Elfsight community! :raised_hands:t2:
