I would like to show a conditional result based on a total calculation. For example, I have 5 sliders with a total possible calculation of 50, I want to show a conditional result if the total is below 20. At the moment, I can only see that I can set conditions based on individual inputs rather than the total outcome.
Hi @Dan_Dowman ![]()
Wonderful idea, thanks for sharing! If other users like it too, it might become a thing ![]()
It would be great to have this function. But it should the condition should just be based on a calculation not matter if total or not. Currently condition can be set only based on fields not on calculations.
I’m creating a calculator for a landscaping client and would love a feature that displays a different image depending on the answer. It is an area calculator.
For instance if the answer is less than 3 cubic meters display “imagesmalltruck” or if the answer is between 3 and 8 cubic meters display “imagemediumtruck”
Lovely suggestion, thank you for sharing, @YV_Media!
We have a similar request to show conditional results based on a total calculation — and I think your idea suits this one, so I’ve moved yours here. I’ll be happy to update you if I have any news about this request ![]()
Are there any updates on this? Thanks!
I highly recommend you guys implement this feature! It would be a gamechanger. I really need it for my use case
Thanks a lot for your comment, @user18407!
We’ll try to consider this suggestion, especially if other users find it useful ![]()
This would be a great addition!
Thanks for upvoting the idea and welcome to the Community, @user19294 ![]()
Would also love the ability to show results (like calculations) based on user input.
For example: show Calculation A if Field B equals C.
Also, it would be great to have this kind of functionality tied to the call-to-action button. For instance, I’m selling smart home gadgets, and depending on whether the customer chooses to install the product themselves or have it installed by us, the CTA button should either link to the shop or to a lead form.
Anyway—upvoted this one! ![]()
Hi there, @D_C ![]()
Many thanks for the feedback!
The idea to implement the conditional logic for the CTA button sounds great. I’ve added a separate request for this feature on your behalf
- Conditional logic for CTA button
I need to be able to show a calculation result if the one calculation result is greater than another calculation result. Currently, you can only select input fields to use for conditional logic/visibility, but you cannot use calculation results
Helllo there, @David46 ![]()
Thanks a heap for sharing your use case!
I totally get your point and agree that this feature would be really helpful. Let’s hope the devs will consider this idea in the future updates ![]()
Friends, we’ve just added an option to show a conditional result based on a calculation value! ![]()
Find the new option under Build → Calculations → Conditional Logic → Conditions:
Does it cover your use case and work as expected?
I’m confused as this has been available for sometime?, I’m waiting on conditional logic for the form fields in the calculator form (very urgent) and a text field entry box in the calculator to be able to add a discount code such as BLACKFRIDAY20 for 20% OFF etc.
Hello there, @Darryl ![]()
The conditional logic for results wasn’t previously available, but now you can hide/show results based on their values.
I also understand your desire to use conditions for form fields. At the moment, we don’t have any specific news to share, but we’ll keep you posted in this thread: Conditional logic for form fields
