Thank you, Max.
I tested it and it works well initially, but if a customer goes back in the form after triggering the button, clicking the next button still opens the “Get Your Free Quote” page instead of behaving normally. I’ve recorded a screen capture to demonstrate the issue. Could this be a limitation of the JavaScript?
Max
January 11, 2026, 10:33am
23
Got it, thanks for sharing a screencast!
I really hope this behavior can be adjusted. Our devs will look into this and I’ll update you once it’s done
Max
January 13, 2026, 10:26am
24
Hi @Michael_Surnak
We’ve adjusted the script:
const widgetSelector =
'.elfsight-app-17536663-c388-4d9c-900b-ac172987f487';
const newButtonLink =
'https://k9poopertroopers.com.au/get-your-free-quote';
const originalTextMap = new WeakMap();
const patchedInputs = new WeakSet();
const boundButtons = new Set();
const rules = [
labelStartsWith:
'What changes would you like to make to your service address/addresses?',
inputSelector: 'input[value="Change a service address"]',
buttonText: 'Get Your Free Quote'
labelStartsWith:
'How many service addresses would you like to add?',
inputSelector: 'input[value="Just one"]',
labelStartsWith:
inputSelector: 'input[value="Multiple"]',
function getActiveRule(container) {
for (const rule of rules) {
const field = [...container.querySelectorAll('[class*="FormFieldLayout__Container-sc"]')]
.find(f => {
const labelEl = f.querySelector('[class*="FormFieldLayout__Label-sc"]');
return (
labelEl &&
labelEl.textContent
.trim()
.toLowerCase()
.startsWith(rule.labelStartsWith.toLowerCase())
if (!field) continue;
const input = field.querySelector(rule.inputSelector);
if (input && input.checked) {
return rule;
return null;
function patchStep(container) {
const buttonEl = container.querySelector(
'button[aria-label="Submit Change Request"]'
if (!buttonEl) return;
const buttonLabel =
buttonEl.querySelector('[class*="ButtonBase__Ellipsis-sc"]') ||
buttonEl;
if (!originalTextMap.has(buttonEl)) {
originalTextMap.set(buttonEl, buttonLabel.textContent);
function syncButtonText() {
const activeRule = getActiveRule(container);
if (activeRule) {
buttonLabel.textContent = activeRule.buttonText;
} else {
originalTextMap.get(buttonEl) ?? buttonLabel.textContent;
if (!boundButtons.has(buttonEl)) {
boundButtons.add(buttonEl);
buttonEl.addEventListener(
'click',
e => {
if (!activeRule) return;
e.preventDefault();
e.stopPropagation();
window.open(newButtonLink, '_blank');
true
rules.forEach(rule => {
.find(f => {
return (
labelEl &&
labelEl.textContent
.trim()
.toLowerCase()
if (!field) return;
if (!input) return;
if (!patchedInputs.has(input)) {
patchedInputs.add(input);
input.addEventListener('change', syncButtonText);
syncButtonText();
const waitForWidget = setInterval(() => {
const container = document.querySelector(widgetSelector);
if (container) {
patchStep(container);
setInterval(() => patchStep(container), 300);
clearInterval(waitForWidget);
}, 300);
Could you please test your widget once again and let me know if any issues appear on your end?
IT WORKS! Thank you Max, I wasn’t sure if it was possible. Thank you to you and the team!
Max
January 14, 2026, 10:48am
26
Perfect, you’re always welcome
I recently updated my form widget installed on this page from “Success message” to “Redirect to URL” on submission—that way I can track submissions better with Facebook Pixel/GTM. Since making this change, the custom JavaScript that modifies the form button to be “Join Our Waiting List” (linking to K9 Pooper Troopers – Join Our Waiting List ) when selecting “No” to the first question no longer works.
Do you have any idea why this might be happening? Sorry to bother you and the team about this again!
Thanks,
Michael
Max
February 10, 2026, 10:46am
28
Hi there, @Michael_Surnak
This script is pretty complex, so changes in the settings might shake things up a bit. But no worries, our devs will adjust the script and I’ll update you once it’s done
Max
February 12, 2026, 3:02pm
30
We’ve adjusted the script and it’s working fine now. Please check it out
Amazing. Thank you Max and the team!
Max
February 13, 2026, 10:10am
32
No sweat!
We’re always here to help if any questions come up
