Click Carousel button > Open Popup
To make a popup on click Carousel on Squarespace, you can follow these.
#1. Create 2 List Popup Page Content with name/URL:
  • List Popup 01 – /list-popup01
  • List Popup 02 – /list-popup02
and Design your content. We will use these pages as Popup Content.
#2. Edit Carousel button >> enter URL:
  • #wm-popup=/list-popup01
  • #wm-popup=/list-popup02
Make sure the option “Open link in new tab” is disabled
#3. Install this popup plugin .
The plugin will give you some code, you can add to Code Injection Header and Footer.
#4. Done. When clicking on the Carousel button >> The Popup will appear
