Click button block - Show Video Popup
Description: Click button block – Show Video Popup in Squarespace.
#1. First, create a page in Not Linked with Name/URL
  • Video Popup - URL: /video-popup
#2. Add 3 Video Blocks to Video Popup Page
#3. Find ID of 3 Video Blocks
In my example, it is:
Video 1: #block-yui_3_17_2_1_1736816377657_11276
Video 2: #block-fd0ae604771edebe0af4
Video 3: #block-e6ffd71e9cc73be5b27b
#4. Edit Button Block where want to make Video Popup appear. Use this URL to 3 Button Block.
Make sure “Open in New Tab” is disabled.
#wm-popup=/video-popup#block-yui_3_17_2_1_1736816377657_11276
#wm-popup=/video-popup#block-fd0ae604771edebe0af4
#wm-popup=/video-popup#block-e6ffd71e9cc73be5b27b
#5. Install Popup Plugin
You can use code: TUAN to get 10% discount
and Footer
#6. Result
When you click on Button > Video Popup will appear.
