Chordpro widget
Create a widget to allow to render lyrics and chords using chordpro standard
@Luis_Arce many thanks for your suggestion and for joining our community! :tada:
We’ll try to think over such a widget in the future, I’ll make sure to keep you posted regarding the status :slight_smile:
Thank you for your help!
