Change language of "Before" and "After" slides to Spanish
Hi there, do you know if it´s possible to change the language of the “before and after” sliders to Spanish in the paid plans? I am based in Spain and would like them to read “Antes” and “Después”, not “before” and “after”. Thank you
Hi @Xabier_Aristu :wave:
Happy to see you with us! Welcome :tada:
Sure thing, you can easily change it your widget settings. Just choose the needed Set on the Content tab and change the text of Before and After Image Label:
