I’d like to control the color of each widget element right in the settings
Friends, I’m happy to say that we’ve started working on this feature! ![]()
It’s currently in the Design stage, and we’ll keep you updated on the progress here ![]()
Love the new AI chatbot feature!! It would be fab to be able to fully customise all colours individually ![]()
Hi there, @Gellert_Kiss and welcome aboard ![]()
Glad to say that we’re currently working on the extended customization options. I’ve moved your comment to thread, where we’ll keep you updated on any developments ![]()
Update: the feature is on the Development stage now! ![]()
Before releasing this feature, please don’t forget to review the CSS codes both @Irene and I have worked on and solved (posted in this community board). One of them, for example, is a CSS code that will allow users to change the color of the AI Chatbot Assistant message timestamp font, and the User message timestamp font. Thank you!
Good point, @Petar_Dietrich! We’ll try to provide a seamless update ![]()
Hey everyone!
We’re happy to share that now you can change the color of each widget element right in the settings.
For this, click on the Customize Theme button on the Theme tab and you’ll see the customization settings for all elements:
Check this post to find other new customization settings -AI Chatbot: Change color of each widget element, font, size settings and more! 🚀
