Is it possible to scroll to the right or left to see additional upcoming events? I want to show a view similar to the grid view, but with just 1 row of events.
Folks, our former Wishlist portal, where our users shared their requests and suggestions, was transferred to this forum. You’re most welcome to vote, add new ideas, and leave your comments here — we surely will consider them all! ![]()
Original Votes: 1
A simple pagination feature would be helpful in Grid view.
Number of events to display : X
Checkbox : Add pagination for additional events
@Francis_Aubert thank you for your comment, and welcome to the community! ![]()
Do you mean that you’d love to display events in Grid view, but use pagination instead of arrows to scroll through all the events?
Currently, website visitors can only see the number of events we’ve chosen to display at one time on a website. It would be very helpful if they could scroll forward (and backward) to see events in the future (and/or the past).
@TappedIn We already have a similar idea in the Wishlist!
I’ve moved your comment to the dedicated thread where we’ll post all the updates ![]()
Thank you.
Hello,
I have a calendar that I have to to update into two calendars because one of them is for a full calendar page (all events), and one is for the homepage (only shows 4, so the homepage doesn’t get crazy long).
I use the card format, and was wondering if there is a way to implement the carousel function with this, so that the 4 cards have an arrow to keep going and showing more events. Folks want their own calendars on their team pages, but I use the 4 cards because their pages would get too scrolly otherwise, and the carousel format only shows one event at a time
Full Calendar: 6c6f22e1-033b-47cd-8ea3-0906acf8c9e4
4 Card Format: c91189de-1315-41a0-a2b6-c03fa3cf7277
This would make things a lot easier so we could display all events without a neverending scroll.
Thanks!
Hi there @Matthew7 ![]()
Currently, there is no way to do this, but we already have a request for the Carousel layout on the Wishlist.
I’ve added your comment to the thread, where we’ll keep you updated ![]()
Thanks for the update.
So realistically our only 2 option are :
- Select a small number of events so the page doesn’t become too overwhelming (we have 100+ events), but folks can’t see most of the events in a category filter OR
- Have a page that displays events that go on and on and on?
Yes, you are right! And one more option is to use a Slider layout for this, but it allows showing only 1 event at once.
I am in the same boat and would like to be in the thread where tells you if this feature is updated. I’d like to be able to show 4 events but have the option to scroll forward or backward for future events rather than having them continue underneath one another.
Thanks a lot for sharing, @Sabrina_Da_SIlva! I also love the idea if a Carousel layout, let’s hope our devs will be able to consider it in the future. We’ll keep you posted in case of any news ![]()
Thank you for your help, and welcome to the community!
Issue description:
Hello, I am wondering if it’s possible to display the events (grid view) ony in one row with the possibility of sliding right and left through all the events instead of having a 2nd row. -
https://www.bear-goes.de/
Cheers,
Kay
Greetings and welcome to the Elfsight family, @Bear ![]()
At the moment, unfortunately, it’s impossible to customize the widget this way. However, this idea is already on the Wishlist, and I’ve moved your comment to the related discussion.
If this request gets more votes, we’ll try to consider this idea in the future ![]()
It would be nice if the Event Calendar Carousel would loop rather than stop rotating at the last event.
Also, viewing more than one event at a time as they scroll through would be ideal.
Thanks
Hi there and welcome to the Community, @Richard_Harrison ![]()
We already have this suggestion on the Wishlist. I’ve moved your comment to the thread, where we’ll keep yoo updated ![]()
Hey everyone!
We’ve started working on this feature and it’s in the Development stage already. We’ll keep you posted on any progress here ![]()
Hey everyone!
We’re happy to share that a Carousel layout is already available in the widget ![]()
Check this post for more details and share your feedback in the post thread - Event Calendar: Enjoy new Carousel layout
