Issue description: widget is connected to my google calendar. No past events show up in the display. The events are listed in the calendar.
Link to the page with the widget in question: testing locally. Here is the code used.
<script src="https://static.elfsight.com/platform/platform.js" async></script> <div class="elfsight-app-1eab7bee-29a1-4700-adf2-1516e0600ac8" data-elfsight-app-lazy></div>
@WAJCI_Senate, welcome aboard! We’re so excited to have you join the community ![]()
I just checked your widget (thanks for the installation code!) and noticed that the past events were just turned off, thus not showing up.
To turn them on, go to Past Events section of the Layout tab. There, click on a toggle and watch the events appear:
Hope it helped! Please let me know if I can assist you further ![]()
