The previous navigation arrow appears on the second slide, however we would like it to be on the first slide as well in the carousel. Is there a way to always display both arrows?
@Make_My_Website many thanks for sharing your suggestion, and welcome to the community!
Although, unfortunately, there is no way to fulfil your use case, we’ll try to consider your idea in our future updates, especially if it gets supported by other Elfsight users ![]()
Thank you very much for helping us!
