Just add this code to the Custom JS field on the Setting tab of your Blog widget’s settings and you’ll be fine:
(function () {
function replaceDivWithH1() {
const elements = document.querySelectorAll('div[class*="post__Title"]');
elements.forEach((el) => {
if (el.tagName.toLowerCase() !== 'div') return;
const h1 = document.createElement('h1');
h1.className = el.className;
h1.innerHTML = el.innerHTML;
Array.from(el.attributes).forEach((attr) => {
if (attr.name !== 'class') {
h1.setAttribute(attr.name, attr.value);
el.replaceWith(h1);
function hookHistoryMethod(methodName) {
const original = history[methodName];
history[methodName] = function (...args) {
const result = original.apply(this, args);
setTimeout(replaceDivWithH1, 50);
return result;
hookHistoryMethod('pushState');
hookHistoryMethod('replaceState');
window.addEventListener('popstate', () => {
setTimeout(replaceDivWithH1, 0);
replaceDivWithH1();
Guys, was this solution helpful? Let us know in the comments ![]()
