If you check the code of the generated article, you’ll see it has no headings:
The modals (popup cards) also have no proper H1 titles and readability structures The paragraphs has no tags.
The lack of an H1 tag for the Title of the article significantly degrades SEO.
Hi there, @Kenley_Lamaute ![]()
Thank you so much for the feedback! We’ll try to consider this functionality in the future, especially if more users upvote it.
As for now, we have a custom solution, adding h1 titles to the widget. For this, please add the code below to the Custom JS field on the Settings tab of your widget’s settings:
const WIDGET_SELECTOR = 'elfsight-app-WIDGET_ID';
new Promise((res) => {
let i = 0;
const check = () => {
if (component) {
res(component);
} else if (i !== 50) {
setTimeout(check, 100);
i++;
check();
waitForElement(`.${WIDGET_SELECTOR} > div`).then((widgetContainer) => {
const title = widgetContainer.querySelector('[class*="header__Title-sc"]');
const titleH1 = document.createElement('h1');
titleH1.className = title.className;
titleH1.style.margin = 0;
titleH1.innerHTML = title.innerHTML;
title.replaceWith(titleH1);
const postTitles = widgetContainer.querySelectorAll(
'[class*="card-content__CardContentTitle-sc"]'
postTitles.forEach((postTitle) => {
const titleH2 = document.createElement('h2');
titleH2.className = postTitle.className;
titleH2.innerHTML = postTitle.innerHTML;
postTitle.replaceWith(titleH2);
const replaseTagsInPost = (post) => {
const popupContainer = document.querySelector(
'.es-portal-root.eapps-blog-6abbfd3f-a8cd-4108-88cd-a40e192b4e3b-custom-css-root'
const postTitle = popupContainer.querySelector('[class*="post__Title-sc"]');
console.log(popupContainer);
console.log(postTitle);
titleH1.className = postTitle.className;
titleH1.innerHTML = postTitle.innerHTML;
postTitle.replaceWith(titleH1);
const posts = widgetContainer.querySelectorAll(
'[class*="card-container__CardContainer-sc"]'
posts.forEach((post) => {
post.addEventListener('click', () => {
setTimeout(function () {
replaseTagsInPost(post);
}, 300);
Do not forget to replace WIDGET_ID in the 1st line of the code with the ID of your widget ![]()
