Better theme
i wish an better theme like: glossy theme, glass theme, based on website theme, and more! Thank you! :blush:
@maxim Many thanks for sharing your suggestions with us!
We’ll try to think about adding more theme options in the future. All the updates will be posted here :slightly_smiling_face:
Thanks! :blush::blush:
Maybe you should also add a feature to create with the themes like different animations, decoration, etc
Thanks, we’ll have it in mind :wink:
Wow! Good idea! @GalacticNetwork !:star_struck::sweat_smile:
@maxim Thank you! :blush:
@Max This should be made cause if you do this like add more themes to every widget, it gives more customization so more people might come to Elfsight due to the fact that you would have different themes of widgets to choose from.
It would grab more attention because POWR or CommonNinja does not do custom themes.
Any Updates here? :slight_smile:
I am sorry to say, but we haven’t got any news yet.
Currently, we have many requests with the higher priority and our devs are actively working on them now.
Once anything comes up, I’ll update you here right away :slightly_smiling_face:
oh its okay! Thanks😁
Hello, any updates to this? :slight_smile:
Hi @maxim :waving_hand:
Unfortunately, we haven’t considered this idea yet. If anything changes, we’ll inform you here :slightly_smiling_face:
Thats fine! :slight_smile:
Hi @Max,
Officially, adding my 2 cents. New themes would be good.
For now I’ll do my usual and check the CSS codes repository to see if there are any there that will allow me the enhance the current aesthetic I am using.
I think this widget has huge untapped potential.
___
m.w. :man_technologist:t5::sparkles:
Got your point, thanks a lot for the feedback!
We’ll try to consider this request in the future, especially if more users upvote it :slightly_smiling_face:
