Better/more layout options for Yelp/Google reviews
I’m embedding a code snippet on my website. It displayes the text spanning the full width which is hard to read. Would be nice to have a two-column layout.
Hey there and welcome to the Community, @Shveta_Aneja :waving_hand:
If you’d like to display your reviews in 2 columns, you should use a Grid layout:
Give it a try and let me know if it covers your needs :wink:
Thank you. I did try the grid layout but that’s too small of a review shown upfront, I want the whole review (or as much) to be displayed right in the page so readers don’t have to click ‘read more’. If there are 4 reviews, they’ll have to click ‘read more’ 4 times and 4 times again to then close the popup. I’d rather have them scroll but display the full review.
I actually switched to all-in-one. Same issue though. I also found a setting to control the width in the List layout which I like better as it shows more of the review upfront.
But the popup showing up when you click ‘see more’ is annoying. I have to reorient myself on where I was and find my place to continue reading. It also changes the font (no longer adopts the website font). I’ll submit a separate request to display the full review in place when you click ‘read more’
So, you’d like to keep the review boxes wide, but display them in multiple columns, am I right?
If so, it’s possible to achieve using the Grid layout. For this, you should increase the widget width/ make it full-width on the Layout tab and set the custom number of columns:
To display the full review text, click on the Customize button on the Review tab and switch How To Display Review Text to Full:
Here is how the widget will look if you follow these steps:
Please try it out and let me know if it worked for you :wink:
