Automatically adjust size based on device
Is it possible to disable scrollbars and have the form automatically adjust height to 100%?
Hi @Josh_Ellis :wave:
Could you please share a direct link to the page where your widget is installed? I’ll be happy to check it for you :slightly_smiling_face:
Sure, its: betterkiwitradie.com
When displayed on mobile device, the form is very compacted. It would be awesome if it could display at full size.
Thank you @Josh_Ellis !
Due to the peculiarities of Google Sites platform, all elements of applications are being converted into iframe format, which causes incorrect displaying.
Iframe calculates the height of the block on mobile based on its size on the desktop. So, to make the widget look good on mobile, you need to stretch the widget in its height on the desktop.
I also need to inform you that an empty space might appear on the desktop below the widget, but it is the only workaround we can suggest in this case. I am really sorry!
