I would love to see the map zoom in on the address entered so that customers would be able to easier find a store nearby. Simply have the map zoom in once their address, or city, or postal code is entered to a 5-20km radius so they can find which retailers fall within their accessibility.
Hi @user33477, welcome to the Community ![]()
Thanks a lot for sharing this idea!
Just to make sure I got it right — you’d like the map to automatically zoom in on the closest location when a user’s search isn’t an exact match (for example, when they enter just a city or postal code). And if the search matches an exact location from the widget list, it should also zoom in on that result.
Did I understand it correctly?
Yes that is exactly correct.
Got it, thanks!
We’ll have your suggestion in mind and if more users upvote it, we might consider it down the line ![]()
