Sorry, but it is not moving here ?
Must I enable this “feature”?
Hi there, @Piero_Biasi1 ![]()
I’ve checked your widgets and see that the animation is working. Could you please double-check it?
Oh.. It’s barely noticable ![]()
You can make the animation more noticable by adding this code to the Custom JS field on the General tab of your widget’s settings:
const styles = document.createElement('style');
styles.innerHTML = `
[class*="dialog-message-dots__Dot-sc"] {
animation: jump 1s infinite;
[class*="dialog-message-dots__Dot-sc"]:nth-child(1) {
animation-delay: 200ms;
[class*="dialog-message-dots__Dot-sc"]:nth-child(2) {
animation-delay: 400ms;
[class*="dialog-message-dots__Dot-sc"]:nth-child(3) {
animation-delay: 600ms;
@keyframes jump {
0% {
bottom: 0px;
opacity: 0.5;
20% {
bottom: 3px;
opacity: 0.3;
40% {
bottom: 0px;
opacity: 0.5;
document.head.append(styles);
Please try it out and let me know if you like the result ![]()
Great solution, it works perfectly for me, and the areas where you can customize it are obvious.
I would suggest that this workaround could be included under Pro Tips.
What do you think?
Yep, absolutely agree! We’ll add this solution to the Pro Tips category ![]()
