Alphabetize event calendar venues and hosts
  • Issue description: venues and hosts need to be alphabetized?
Hi there, @Bernie_Martin :waving_hand:
If you’d like to display the venues and hosts in the alphabetical order in the filters, you can do this using the Alphabetical sorting on the Filters tabs:
In case, you’re referring to the alphabetical order in the configurator list, unfortunately this functionality isn’t supported now. However, this idea is already on the Wishlist and you can upvote it here :slightly_smiling_face: - Sort venues/hosts in the venue/host list in the configurator alphabetically
