Currently if I don’t want my announcement bar-widget being displayed for a period of time, I have to select the background to transparent and text to white.
Is there a way we could have a ‘one-click’ way to effectively ‘un-publish’?
Sure! You can hide the widget on your website right from the dashboard. Just click 3 dots next your widget and choose Hide from Website:
Also, I’d like to remind you about the Schedule option on the Settings tab. Here, you can set the date and time when the widget will be displayed on the website:
However, I’d recommend you using the Hide from Website feature. This way, the views won’t be counted when the widget isn’t shown on the pages ![]()
Many thanks for that Max.
No problem!
By the way, we’d like to invite you to join our new challenge. This time, you should create a slogan for Elfsight to win a 6-month extension to your subscription.
Check the details and join in: October Challenge: Create Slogan for Elfsight and Win 6 Free Months! (+2 weeks guaranteed)
We’ll be super happy to see you as a participant ![]()
Having forgotten I had ‘hidden’ this widget, but then had AI help remind me about the Hide/Unhide option, I just wanted to again lodge a complaint/comment that I think this is a REALLY horrible bit of UI/UX on the Elfsight dashboard.
The menu elipses to show these options are, on my screen away to the RH side, and certainly easily overlooked. This bit of awfulness could so easily be nicely solved by ten minutes coding tweak on this page to get the Hide/Unhide options closer to where the Edit link is, even turning the ‘eye’ icon into a toggling link that would do the Hiding or Unhiding would be a huge improvement over what we have now!
…sigh
Hello there, @user16632 ![]()
Thanks a lot for sharing your thoughts with us!
I totally get your point and passed your feedback on to the dev team. Additionally, I’ve created a Wishlist request for this imporvement on your behalf - Make Hide/Show on website button more noticeable.
If more users support it, we’ll try to consider it in the future updates ![]()
