If you want to add time delay to certain blocks on Squarespace, you can follow these simple steps.
- Blocks will appear after some seconds
- If you can’t make it work, you can comment or message me with link to page where you use blocks, I can check easier.
#1. Install Squarespace ID Finder to find the ID of Block.
In my example, we will have:
- #block-yui_3_17_2_1_1719906734967_2500
#2. Use this code to Custom CSS box
#block-yui_3_17_2_1_1719906734967_2500 {
animation: showX 2s 10s forwards;
opacity: 0;
@keyframes showX {
to { opacity: 1; }
