Spectora is a home inspector software. They have a system to collect reviews but the reviews stay on spectora.com. No one sees them unless they go there and search for them. They are on this page, Spectora Login | Spectora Software Account Login
Hey there @user152
Thank you so much for adding your idea to the Wishlist!
If this request is going to gain ground, we’ll try our best to consider the Spectora source in one of our future updates.
