Add Mailerlite integration
Greetings @Tabu_CBD and welcome aboard :wave:
Thanks a bunch for adding your idea to our Wishlist!
I can’t promise that this integration will be definitely implemented. However, if it’s going to gain ground, our devs will try to think it over in our future updates :slightly_smiling_face:
Hi @Max! Any update on whether MailerLite is being considered on the roadmap?
FWIW - If this integration existed I would buy the Contact Form or Custom Form widget in a heartbeat! And, since I came here for the Event Calendar I might even get the whole 87 app bundle…and I’m sure I’m not the only one.
Hey @LizHayley and welcome to the Community :wave:
Thank you so much for sharing your feedback with us!
I totally understand your point and agree that it would be awesome to have a MailerLite integration available for our Forms apps. We’ll try to consider its implementation in the future and I’ll make sure to keep you updated here :slightly_smiling_face:
As a workaround, you can use Zapier integration where 5000+ services are available (including MailerLite).
Here is an article explaining how to integrate your Form widget with Zapier - How to integrate your Form widget with Zapier - Elfsight Help Center.
I would love mailerlite being integrated.
That would me buy contactform etc.
Thanks!
Hey there and welcome to the Community, @user18167 :wave:
Thanks for upvoting the idea! If this request gains more votes, we’ll try to think about this integration down the line :slightly_smiling_face:
I agree, I use mailerlite and would hope to see this integrated soon.
Thanks a lot for supporting the requests you’d love to see implemented, @Sara_Lamont!
We’ll be happy to post here as soon as we have any news :slight_smile:
