Add locations by pindrop or altitude/longitude
It would be great if you can filter by categories and sub categories. Also the ability to add location by pin drop or latitude / longitude.
Hi there @Robbie_Shipman :wave:
Glad to say that we already have a request for the Categories/Filters. You can vote for this idea here - Categories/filters.
As for the 2nd suggestion, we agree that it would be a nice enhancement too. So, let’s see how others feel about it :slightly_smiling_face:
I tried with lat/long in the “location” field and imported bulk from CSV, this worked perfectly.
Hey there, @user1086 and welcome to the Community :wave:
Thank you so much for the note!
You are right, you can use the coordinates to add location when importing locations from a CSV file.
Also, you can try to add locations by coordinates right in the widget, but you’ll get a list of locations nearby, and you’ll should choose the correct one.
Thus, for now, we recommend using location name and address when adding locations in the widget.
@Robbie_Shipman Anyway, feel free to test it out :slightly_smiling_face:
