Add info popup for all location (like in Google Maps)
Thank you. It works. I just want to ask if is there anyway that the info shows on each location pin just like the Google Map Widget feature? Thanks.
Hi there, @Leana_Nhan :wave:
Do you mean the popup for the locations which are not added to the widget like this in Google Maps?
Yes that is correct. Instead of just popping at one place. I would rather suggest to have something like this.
Got it, thanks!
Currently, unfortunately, it’s impossible to do this. I’ve added this idea as a separate Wishlist request and we’ll try to think it over in the future :slightly_smiling_face:
