Provide Link that can be used to post to Instagram
Hi there @Gina_Quinn ![]()
If I understood you correctly, you’d like to have a separate field where you would add links to your social channels. I agree that it would be a great addition and we’ll try to consider this opportunity ![]()
I’ve checked your widget and see that you are not using buttons for your events. So, as a workaround, you can try to enable buttons and add a link to your Instagram profile there:
Thats hard… ![]()
I can’t help you with that.
