Add custom HTML, CSS and JAVASCRIPT to a blank frame
Hello, I was wondering if there is a way to add custom HTML, CSS and JAVASCRIPT to a blank frame that I can then embed into Portfoliobox?
Hi @Shoeb_Lakhi :wave:
Thank you for sharing this idea!
Would it be an option for you to describe your use case in more detail?
Hi again @Shoeb_Lakhi :wave:
I wanted to follow up on my previous message and specify if your idea is to have an app that allows to add HTML, JavaScript codes to the Portfoliobox websites. As for the CSS, I see that it’s possible to add custom codes there:
Or maybe you just want to install Elfsight widgets to your Portfoliobox website? Your response would be much appreciated :wink:
