Can you add a custom color schema to the map? Same like in the Google Maps widget?
Hello there, @Joshua_Habener ![]()
This is a great idea! If more users support, we’ll try to consider this opportunity in the future updates ![]()
Thank you for the feedback!
Yes, and satellite view please.
Hey there, @Yunus_Guneyli and thanks for upvoting this idea ![]()
Regarding the satellite view suggestion, I’ve added a separate request for this - Satellite map view
