if i have several points and map is zoomed out, I’d like to cluster pins under one big dot with number of pins in it. because currently maps is not cool with all those pins x)
Greetings and welcome aboard, @Reda_Malas ![]()
Nice idea, thanks for sharing! Let’s see if other users would like to have this feature too ![]()
Yes, it will be a great option that. Google Maps have that option, i think it will be great to have it in store location. Many options from Google Maps it will be great to transfer also!
Hi there, @mantolis360 and welcome aboard ![]()
Many thanks for the feedback!
Could you please describe what other options from Google Maps you’d like to see in the Store Locator?
Hi Max, Thank u for your reply.
I think:
Clusters is important for better visitor experience to avoid Overlap poi
Distance Units Miles / Km, now is only Miles
Marker Icon size
Width & Height
Center & Zoom
Best Regards, Apostolis
Got it, thanks!
1. The distance unit depends on the language chosen in the settings. Since the traditional measure unit in the USA is miles, it will be used when choosing English (US). However, if you choose, for example, English (Australia), miles will be replaced with kilometers:
2. We already have a request for the Marker size setting, and you can upvote this idea here - Setting to change marker size
3. Map Center and Zoom options, where you can set auto or custom values are already available on the Settings tab.
Do these options work for you or you wanted to have Min/Max Zoom and Map Bound restrictions as well?
Hello Max, Thank u for your reply.
- I understand your “idea” for Miles/Km but in Europe we have km and is common to use English US as for language. In your other app Google Map i must enter manual if i want Ml or km. I preferred that for my opinion.
- excellent, i’;ll check it
- Compare it with google map i preferred the restrictions
Here you have make excellent work with button and working hours.
ill come back with other notes ![]()
Best Regards
Apostolis
Got you! I’ve added these suggestions to the Wishlist on your behalf ![]()
