Add bookshelf feature
The flipbook will be more complete with a bookshelf feature, and the bookshelf image can be customized.
Thank you for sharing your idea, @Shovwan_Shany_Hanum, and welcome to the community!
Just to clarify, you’d like an option to create a bookshelf where you can add multiple files for your customers to choose from, right?
Yes, that’s right.
Hello Elfsight team,
I’d like to suggest an enhancement for the Flipbook widget.
Currently, the widget allows us to display and flip through a single PDF file beautifully. My suggestion is to add a “library view” feature, where multiple PDFs could be displayed together on the same page — like a digital bookshelf.
Users could then “pick” one of the publications from the shelf and flip through it within the same page, without opening a new tab or separate view.
This feature would be ideal for magazine archives, portfolios, or catalog collections — providing a much richer and more immersive user experience.
Thank you for considering this improvement!
Best regards,
Klayton Georgio
Hi there, @Klayton :waving_hand:
Thanks a lot for the feedback!
We already have a similar Wishlist request. I’ve moved your comment to the related thread, where we’ll keep you in the loop :slightly_smiling_face:
