Add a Title for each reviewer
Hello, can you add a field right under the reviewer’s name where their “title” can be entered? Like replacing the website location?
Hi there, @CHRISTOPH_merrill and welcome aboard :waving_hand:
You can add a bold title right in the Testimonial Text section:
If you want to use a different font size for the title, open the Code Editor mode in the Testimonial Text field:
Then, wrap your title in the <span> tag with the needed font size. Here is how it looks:
<span style="font-size: 20px;">Title</span>
Give it a try and let me know how it worked for you :wink:
In the example above, Taylor J. See the “Event Planner” where the domain name usually goes, I’d like to add it there, so it represents the corporate role the reviewer represents, and so I can still have a tilte for the review. Is there a way to do that?
I was playing around with the LinkedIn version, and that has the “Reviewer “job title, but doesn’t have the “review title.” Having fun!
Ah, I see what you mean! You can use a Caption field for the job title. You just need to enable the caption display on the Testimonial tab:
Please check it out and let me know if it works for you :slightly_smiling_face:
