Ability to vertically-align testimonials in slider
At the moment, the testimonials are vertically aligned at the top of the widget, but as my testimonials are different lengths, that means that the shorter ones have a lot of space at the bottom, and the longer ones fill up the vertical space better.
Welcome to the Community @Antony_Wootten :wave:
Do I understand correctly that you’d like to remove this spacing for the short testimonials?
Hi, thanks for getting back to me. Yes, that’s correct. I’d like to vertically align the text so that there is equal white space above and below the text.
I’ve talked to our devs and, unfortunately, there is no option to remove this extra space as your website is built on absolute positioning.
Please let me know if this explains things or if you have any further questions :slightly_smiling_face:
