Ability to link products on the flipbook pages with another pages
it would be nice to have selections in each page that can link to the pages (products) for example. You have 5 products on on a page. so viewers can click on those products en get directed to the buy pages.
Hi there @user3229 :wave:
Great idea, thanks for sharing! We’ll keep an eye on how popular it gets :wink:
Folks, we’ve reviewed this request and found you can add links to the product images in your PDF file itself, which means this feature isn’t required to be in the widget.
Here is how you can do this:
  1. Open your PDF file in Adobe Acrobat Pro.
  2. Click ToolsEdit PDF.
  3. In the top menu, choose LinkAdd/Edit Web or Document Link.
  4. Draw a rectangle over the image you want to make clickable.
  5. In the popup window select Open a web page if you want the image to lead to a website. Then click Next
  6. Paste the full link, click OK and save the file
Please try it out and let us know if it worked fo ryou :wink:
