What I am looking for is the ability for the user to select various products (via a tick box), and then only compare the selected items
Hi there, @Achim_Roetger ![]()
I like this idea, thanks for sharing! Now let’s see if other users feel the same way ![]()
Hi there, it would be great to embed here such an option, then in the Portfolio widget - the ability to categorise the columns and the possibility to filter them. Is it possible to make it?
Hi there, @David_Molnar ![]()
I am afraid I didn’t quite get you!
Would you like to have a filter option in the Pricing Table widget or in the Portfolio? Or maybe in both?
Sorry, I was not as clear as I wanted to be.
So, I’m missing a category filter option from the Pricing Table widget. You already have this kind of filter opportunity in the Portfolio that would perfectly work for me in the Pricing Table widget, too.
And again, sorry for the confusion.
I see, thank you so much for clarification!
We’ll keep this idea in mind and wait for more feedback from other members. If this request becomes popular, we’ll try to think it over in the futre updates ![]()
